Just a general question about the learning curve for making PCB’s on your CNC. I have nearly completed my web controlled Arduino BB RC Tank project I’m still coding (and really enjoying it) but there’s not really enough space for the Arduino boards ..so I thought I would make PCB from scratch using Ladyada kits or even buy the parts and put it together to make it smaller or even make it fit better ina strange shape. Anyway is there any point to putting a lot of hours into learning everything I need to produce a PCB for it ? I think the biggest problem I would have is the drawing the schematics as I don’t have a that much of an electronics background, besides perf board any alternatives ?
Ralph Waldo Emerson
04-04-2013 #2
Shouldn't be that bad.
Have a play with eagle cad and do a couple of simple circuits, there is also MillPCBS.com with some advice & vids for milling your own pcb's.
04-04-2013 #3
I use DipTrace for designing my pcb's.
I have tried the tonner xfer, and the uv xfer, this is before I had my cnc.
Using the CNC to cut the tracks and drill holes is much quicker, but I still prefer the etched pcbs to engraved pcb's."If first you don't succeed, redefine success"
04-04-2013 #4
I use EagleCad for designing the boards and an add in ulp called pcb-gcode to make gcode files.
You can download Eagle and use it as freeware for "small" boards" and hobby use and the add in is also freeware and can be found on the eagle site or through its yahoo group:
pcb-gcode : The pcb-gcode User's Group
Works great for those one off boards and if you want "autoleveling", there is a version that runs on an older version of eagle also.Art
AKA Country Bubba
(Older than Dirt)
04-04-2013 #5
Has anybody tried a combination cnc and etching for pcb's. Just coat the pcb with resist(paint will do) and scratch the outline on the cnc and then etch in ferric chloride, just a thought.
Peter
04-04-2013 #6
I mill my own pcbs all the time....the win for me is turnaround time (from completing the circuit to having the board in my hand is about 1hr ...on par with chemical etching but the results are more predictable & also the holes are done at the end of the process - and the pcb outline/mount holes sorted). I've tried most CNC pcb milling methods & associated apps,here's what I settled on...
1. Design cct in Eagle
2. Export track layer (from the Eagle board) to a gerber file
3. Import gerber file to cambam - cam it up.
4. Save g-code
5. Open g-code in CNC-USB
6. Probe actual FR4 copper surface with CNC-USB (then use probed data to update the Z height data sourced from your g-code file)
7. Mill board.
The problem with milling pcb is one of height irregularities - it doesn't take much error with a V cutter to end up with a track that is not isolated etc....especially with SMD components (which is what I typically use) That's why I went with CNC-USB ...it has an integrated feature called warp (step 6 above).
It's apprently possible to do a similar thing to 'warp' with an Eagle plugin called pcb-gcode...I tried with mixed/frustrating results.Last edited by HankMcSpank; 04-04-2013 at 06:16 PM.
gerber to dxf for PCBs
By Web Goblin in forum Computer SoftwareReplies: 4Last Post: 26-10-2013, 08:25 PM -
Where to get PCBs made in reasonable quantities?
By Jonathan in forum General ElectronicsReplies: 7Last Post: 07-09-2013, 05:25 PM -
NEW MEMBER: PCBs - desktop CNC - Hi from salisbury
By Plod in forum New Member IntroductionsReplies: 10Last Post: 07-09-2013, 09:34 AM -
RFQ: Why is it so hard...
By ktc in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-08-2013, 08:05 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM
